In the Cold North - Forum RPG
Re: In the Cold North - Forum RPG
Postby mgb519 » Wed May 15, 2013 9:02 am
Adarim
Open the door which isn't blocked. Everyone else ought to cover me.
Postby Silverdream » Wed May 15, 2013 10:48 am
I put the stone in my backpack.
Postby mgb519 » Wed May 15, 2013 11:10 am
Adarim
"I'd like to suggest that we map out as much as we can before we investigate. I don't like the idea of enemies lurking in rooms we don't know about."
Postby Arkbrik » Wed May 15, 2013 4:36 pm
Saucix bags the stone, and Adarim opens the first door. Behind it is a small antechamber with another door on the opposite wall. This door seems stronger than the others, with a heavy lock... but the lock has been smashed apart and the door stands slightly ajar. By the looks of it, the lock was not smashed recently.
Overwatch:
Postby IVhorseman » Wed May 15, 2013 4:53 pm
Hey don't open that door yet. I've got a bad feeling about it. Go do the other stuff, and by the time you do, Nisos and I should be done training the mink. Or at least, I'll be done helping him.
Postby mgb519 » Wed May 15, 2013 5:07 pm
Adarim
Backtrack to the other two unopened doors. It looks like they go to the same corner room.
Postby Silverdream » Wed May 15, 2013 6:21 pm
Remove the chair covering the door from our right, and open it.
Postby Quantumsurfer » Wed May 15, 2013 7:15 pm
I will be constantly maneuvering into the best position for a possible sneak attack.  Basically skulking around while trying to cover everyone's backs and keep an eye on things.
Thank god for Colette.
Postby Arkbrik » Wed May 15, 2013 11:58 pm
mgb519 wrote:Adarim
Silverdream wrote:Remove the chair covering the door from our right, and open it.
Are you going to do that at the same time?
Postby Silverdream » Thu May 16, 2013 12:44 am
Oh, I thought Adarim wanted to walk someplace else.
Postby mgb519 » Thu May 16, 2013 8:49 am
I meant the ones on the other side of the map.
Postby IVhorseman » Thu May 16, 2013 11:42 am
The bottom right corner room?
Postby Arkbrik » Thu May 16, 2013 2:25 pm
You go back to the room where the mink was. Adarim steps up to the door leading to what seems to be a (bottom right) corner room, and pushes the handle down... but finds that the door is locked.
Postby Silverdream » Thu May 16, 2013 2:29 pm
"Well, it looks like we're stuck. Perhaps those goblins had the key."
Postby IVhorseman » Thu May 16, 2013 2:39 pm
"Make Gregor do it. He's the one equipped for such a task."
