In the Cold North - Forum RPG
Re: In the Cold North - Forum RPG
Postby Arkbrik » Tue Jul 02, 2013 3:44 am
There are no obvious traps on the sword. If you had a Detect Magic spell you could check it for enchantments without touching it, but I'll assume you go ahead and pick it up.
As you do, heat immediately spreads from your hand throughout the rest of your body. You no longer feel the ice-cold air of the stone chamber; it's like you are standing before a warm hearthfire.
The runes on the sword are similar to those on the map you took from Fyespon, and the general style of the sword's decorations reminds you of that mural in another room of this complex.
Here is a better look at the runes on the sword:
And here is Fyespon's map again:
Gregor tries to move the table so it stands across the door, but he'll need help from someone stronger to get that huge piece of stone furniture moving.
Postby mgb519 » Tue Jul 02, 2013 9:41 am
Adarim
Help Gregor move the table.
Postby Arkbrik » Tue Jul 02, 2013 3:10 pm
With combined strength, Gregor and Adarim push the table against the doorway. As they do so, you hear a rattling sound from inside it, like bits of metal hitting each other.
Postby Quantumsurfer » Tue Jul 02, 2013 3:19 pm
Let's take a look inside.
Does the map indicate another magical item somewhere else then?
Postby Silverdream » Tue Jul 02, 2013 3:28 pm
I give the sword to Gerald, even though there's very little difference in our damge output.
Postby Arkbrik » Tue Jul 02, 2013 3:36 pm
Gregor looks over the stone table, and finds that part of the underside is hollow. Behind a sliding stone panel is a compartment containing a pile of large, thin gold coins! The only decoration on the coins is a spiral on each side. There are 110 of them.
Gerald gets the warming sword.
Postby Silverdream » Tue Jul 02, 2013 3:59 pm
Don't steal them, remember Pirates of the carribean?
Postby Quantumsurfer » Tue Jul 02, 2013 5:52 pm
I steal them.
Postby IVhorseman » Wed Jul 03, 2013 1:09 am
Definitely take the coins. As far as I can tell, everything that Saucix suggests is pretty much the opposite of what should happen.
"This blade burns like the Sun. It will do well in my arm, paired with my shield. I suspect that these runes are script for a language, though I cannot fathom whom it may belong to. It seems too neat for goblin work."
Postby Arkbrik » Wed Jul 03, 2013 4:07 pm
So Gregor and Gerald want a share of the gold, what about Nisos and Adarim?
Also, do you descend into the pit in some particular clever way?
Postby mgb519 » Wed Jul 03, 2013 4:38 pm
Of course Adarim wants a share of the gold. Life on the run is hard, you know.
Postby IVhorseman » Thu Jul 04, 2013 11:05 am
IVhorseman wrote:Somebody toss a rope down the hole and tie one end to something sturdy, yeah? We're going in.
Postby Arkbrik » Sat Jul 06, 2013 5:15 am
You tie the rope to the table and throw the other end down into the darkness. You're not quite sure if it reaches the bottom. Who will be the first down?
I'm away at a party thingie for a few days, so I can only check on this sporadically now.
Postby Scratch » Sat Jul 06, 2013 12:23 pm
I volunteer to go last!
Zupponn wrote:
Scratch
Reihawk
Postby mgb519 » Sat Jul 06, 2013 1:51 pm
Adarim
I go first. Someone has to.
