In the Cold North - Forum RPG
Moderators: Olothontor, Timedude
Re: In the Cold North - Forum RPG
Postby mgb519 » Wed Feb 19, 2014 7:40 pm
Adarim
"Tithe what you will, for you are the leader. But know that you do so without our support.
Postby Scratch » Wed Feb 19, 2014 9:53 pm
"As a member of the church, wouldn't you be paid and fed from the 40%, while we would see none of it? Why don't we go for a more reasonable margin, 40% for you and the church, and 60% for the rest of us, and if I recall my scripture, does it not say "Give 10% to Pakkan, or 15% accounting for inflation?"
Zupponn wrote:
Scratch
Reihawk
Postby Silverdream » Wed Feb 19, 2014 10:29 pm
Scratch wrote:"As a member of the church, wouldn't you be paid and fed from the 40%, while we would see none of it? Why don't we go for a more reasonable margin, 40% for you and the church, and 60% for the rest of us, and if I recall my scripture, does it not say "Give 10% to Pakkan, or 15% accounting for inflation?"
"You make a fair point. Split the 60% among yourselves."
Postby Arkbrik » Fri Feb 21, 2014 8:18 am
With no further complaints, Saucix splits the gold. There are a total of 435 coins. Saucix takes 175 coins for the church. Gerald, Gregor, Nisos and Adarim split the rest, taking 65 coins each.
Overwatch:
(Actually you are in the topmost room with the golden statue, but whatever)
Postby Arkbrik » Tue Mar 11, 2014 2:06 pm
Bump, yo. What to do next?
Postby Quantumsurfer » Tue Mar 11, 2014 4:47 pm
"Hey, can we get through that door?"
Postby Scratch » Sat Mar 29, 2014 12:11 am
"Let's try that"
Zupponn wrote:
Scratch
Reihawk
Postby Silverdream » Sat Mar 29, 2014 1:12 am
"I'll do it."
Try the door.
Postby Arkbrik » Sat Mar 29, 2014 4:51 am
(It seems IV is not around, I'll run his character until he shows up.)
This is another door with a hole instead of handle and keyhole, so Gerald inserts the goblin bracelet and the door opens. You come into a tunnel going east and then turning south, ending at a statue identical to the one you found before: the upper body of a snake-headed humanoid made from dark metal. The arms are outstretched and a look at the joints show you that the arms are posable, just like the arms on the other statue.
Overwatch:
Postby Quantumsurfer » Sat Mar 29, 2014 3:20 pm
Should we see if there is a correlation in arm positioning?
Postby Scratch » Sat Mar 29, 2014 3:46 pm
"One of use should go back and try to match the positions, but what positions should we use?"
Zupponn wrote:
Scratch
Reihawk
Postby Silverdream » Sat Mar 29, 2014 6:01 pm
I will go to the other statue, memorize the position and come back here.
Postby Arkbrik » Sat Mar 29, 2014 11:42 pm
Saucix goes to the other statue. It has one arm raised and one arm pointing forwards after Nisos moved the arms around to check the armpits and pull at an arm.
Postby Scratch » Sun Mar 30, 2014 9:52 pm
Do we remember the original pose?
Zupponn wrote:
Scratch
Reihawk
Postby Arkbrik » Mon Mar 31, 2014 5:30 am
Just like the second statue, the first statue had its arms outstretched forward to begin with.
Saucix heads back to the rest of party past the great golden snakeperson statue in the treasure room, thinking deeply.
