The NGS
Re: NGS X360 Fighter
Postby Apollyon » Fri Feb 21, 2014 5:00 am
Silverdream wrote:
Tzan wrote:Image
Alt detected. Why would you post a pic with better lighting under your Tzan account?
Is there an easy way to improve pictures in this way or does it take a lot of work? (using Gimp)
Apollyon
Postby Tzan » Fri Feb 21, 2014 10:44 am
Well it does take some work. But its not hard.
I don't have Gimp, but I can explain what to do in Photoshop.
With this image all I did was 2 things.
6. Image > Adjust > Auto Levels
7. buttplug > Sharpen > Sharpen
The one I posted before I also did some color balance.
I was trying to fix the yellowed white areas, but those may actually be a bit yellow, so adding blue seemed to make it too blue.
So the one I posted here is fine.
Sometimes Auto levels changes things too much and makes things worse.
You can see in this image that the white areas are more extremely white, in the previous image I manually adjusted Levels and didn't go so far as.
Nice fighter!
Re: The NGS
Postby M220 » Fri Feb 13, 2015 12:31 am
Hi all!
It's been exactly one year since I've joined the forums, and I guarantee there be many more years in which I'll continue participating.
To ascertain my statement, I present you the Nitronian Galactic Starfleet, otherwise known as the NGS:
The Nitronian Galactic Starfleet was first commissioned in B.R.2013 after most of the Nitronian Marine Corps had defected under the leadership of General Arburst of the Wartirnian Mercenaries. The fleet consists of mainly light infantry and heavy starships to accomplish fast and hard hitting operations. Nitronian invasion of planets in nearby systems has also been carried out by the NGS. The Starfleet, relatively new and unknown, is under constant expansion and development.
First up, the NGS X09 Light Fighter:
Front:
Side:
Rear:
Stats:
Armour: 2d10
Movement: 8" Flying
Crew: 1
Armament:
x2 Lances
x2 Miniguns
The NGS X360 Fighter.
Stats:
Armour: 3d10
Movement: 18" Flying
Crew: 2
Armament:
x6 Miniguns
x2 Anti Infantry Machine guns
x2 Heavy Machine guns
x4 Anti Aircraft Missiles
x10 Meteor Missiles
And finally, the TITAN Class Troop Carrier:
Front:
Side:
Rear:
TITAN Class Troop Carrier and Infantry:
Stats:
Armour: 3d10+5
Movement: 16" Flying
Capacity: 28+ (not including crew and infantry)
Crew: 7 (including infantry)
Armament:
x4 Miniguns
x4 Lances
x2 Heavy Cannons
x8 Meteor Missiles
x1 AA Turret
More updates should be available within the next two weeks.
Mnds are like parachutes. Just because you've lost yours doesn't mean you can borrow mine.
M220
Re: The NGS
Postby Bluefog » Fri Feb 13, 2015 10:36 am
Damn peaches. Cool stuff though.
Bluefog
Re: The NGS
Postby ikensall » Fri Feb 13, 2015 1:29 pm
Great build quiality, nothing looks out of place.
ikensall
Princess Cauliflower
Re: The NGS
Postby Colette » Fri Feb 13, 2015 2:49 pm
Holy fracking shit, it's alive!
Re: The NGS
Postby Vami IV » Fri Feb 13, 2015 10:49 pm
That fighter looks pretty good, given some blockiness. Keep it up.
