Moderators: 501stCadians, Ross_Varn
Tzan wrote:Semaj Nagirrac wrote:Well, I took some land without checking if it was owned by a faction or not. I'm not going to be banned, am I? I can destroy everything if need be.
1AM Steamchat wrote:12:47 AM - Matthewbri: alright
12:47 AM - Matthewbri: here's your first lesson
12:47 AM - Matthewbri: what do you see there
12:48 AM - [BriK] Ross Varn expands window
12:48 AM - [BriK] Ross Varn: I see
12:48 AM - [BriK] Ross Varn: Charlie Foxtrot
12:48 AM - Matthewbri: now that
12:48 AM - Matthewbri: is caused
12:48 AM - Matthewbri: by this
12:48 AM - Matthewbri: 2012-04-08 21:26:41 [SEVERE] Could not pass event PlayerLoginEvent to CommandBook
org.bukkit.event.EventException
at org.bukkit.plugin.java.JavaPluginLoader$1.execute(JavaPluginLoader.java:303)
at org.bukkit.plugin.RegisteredListener.callEvent(RegisteredListener.java:62)
at org.bukkit.plugin.SimplePluginManager.callEvent(SimplePluginManager.java:459)
at net.minecraft.server.ServerConfigurationManager.attemptLogin(ServerConfigurationManager.java:227)
at net.minecraft.server.NetLoginHandler.b(NetLoginHandler.java:102)
at net.minecraft.server.NetLoginHandler.a(NetLoginHandler.java:41)
at net.minecraft.server.NetworkListenThread.a(NetworkListenThread.java:61)
at net.minecraft.server.MinecraftServer.w(MinecraftServer.java:551)
at net.minecraft.server.MinecraftServer.run(MinecraftServer.java:449)
at net.minecraft.server.ThreadServerApplication.run(SourceFile:492)
Caused by: java.lang.RuntimeException: No groups defined. Check your permissions file.
at ru.tehkode.permissions.backends.FileBackend.getDefaultGroup(FileBackend.java:139)
at ru.tehkode.permissions.PermissionManager.getDefaultGroup(PermissionManager.java:288)
at ru.tehkode.permissions.PermissionManager.getDefaultGroup(PermissionManager.java:277)
at ru.tehkode.permissions.PermissionUser.getGroups(PermissionUser.java:221)
at ru.tehkode.permissions.PermissionUser.getOption(PermissionUser.java:132)
at ru.tehkode.permissions.PermissionEntity.getOptionBoolean(PermissionEntity.java:298)
at ru.tehkode.permissions.PermissionEntity.initialize(PermissionEntity.java:57)
at ru.tehkode.permissions.PermissionUser.initialize(PermissionUser.java:53)
at ru.tehkode.permissions.ProxyPermissionUser.initialize(ProxyPermissionUser.java:41)
at ru.tehkode.permissions.PermissionManager.getUser(PermissionManager.java:115)
at ru.tehkode.permissions.PermissionManager.has(PermissionManager.java:90)
at com.sk89q.wepif.PermissionsExResolver.hasPermission(PermissionsExResolver.java:63)
at com.sk89q.wepif.PermissionsResolverManager.hasPermission(PermissionsResolverManag
12:48 AM - Matthewbri: what do you see there
12:50 AM - [BriK] Ross Varn: relation between the previous errors and a number of things that are probably core processes on the server- .minecraftserver.run, login handler, etc- down to the "permissions" bit. If I had to hazard a guess I'd say that there's a disperancy between an update and Bukkit but that's just because I saw the word Bukkit in the last line of the other string
12:51 AM - Matthewbri highfives Geddy
12:51 AM - Matthewbri: bang on
12:51 AM - Matthewbri: basically
12:51 AM - Matthewbri: commandbook is going
12:51 AM - Matthewbri: DERP
12:51 AM - Matthewbri: which makes permissons go FUUUUU
12:51 AM - Matthewbri: and the whole house of cards falls like dominos.
12:51 AM - Matthewbri: checkmate.
Tzan wrote:My point was that if you are a dedicated gamer, you are already a slacker.
But yeah you need to get your real life stuff in order before gaming.
