While you're waiting on your server..
terraria, dwarf fortress, whatever, they're all the same damn game
Moderators: Ross_Varn, 501stCadians, dilanski
Postby Ross_Varn » Thu Sep 29, 2011 10:41 am
Can't build on enemy territory. They'd have to damage us considerably to take out our power.
In the Factions plugin, there is a stat called Power. This is present on the Brikwars server as well. Type /f who [faction name] to view a faction's power. The stat follows: land (# of chunks(16x16 squares)) / current power / maximum power. Bastion's is about 26/54/90.
Each player has a max power of 10, which decreased by 2 when you die. In the Bastion server, it also decreases by 1 for each day that you're offline, and increases while you're online.
The current and total power of a faction is the sum of their member's power. If the faction's current power is less than their land number, enemy factions can claim their land. So, the steps of a raid are-
kill enemy until land>power
claim enemy land at edge of territory
continue until base is breached and you dump lava on their spawnpoint
Something that most factions won't think of are TnT cannons. They won't be able to detonate TnT directly on the walls, but they could build one out in the sea to blow the walls out with. We'd have to take aggressive action in this instance.
Postby AlphaLurker » Thu Sep 29, 2011 12:06 pm
.....OR you could use a torch to hold up the gravel.
EXTERMINATE!
On a quest to destroy all organic life, since 1875.
My MocPages account:
http://mocpages.com/home.php/57591
AlphaLurker
Postby knolli » Thu Sep 29, 2011 12:23 pm
To do that you have to dig below the gravel, which isn't too healthy either, I guess.
knolli
Postby AlphaLurker » Thu Sep 29, 2011 12:31 pm
knolli wrote:To do that you have to dig below the gravel, which isn't too healthy either, I guess.
What, did you mine out all the blocks around your base and put lava falls instead? nah, diggy diggy is the best way to go, in my oppinion.
EXTERMINATE!
AlphaLurker
Postby Olothontor » Thu Sep 29, 2011 12:55 pm
The problem being that digging is dangerous for your health around gravel. Plus, you can't exactly place a torch once the gravel is already falling. I'm fairly certain you'd have to be incredibly quick with your cursor, if it's not impossible.
Postby AlphaLurker » Thu Sep 29, 2011 1:11 pm
..........Yeah, well, that's beside the point. I know how to effectively defend one's castle from a TNT canon.
EXTERMINATE!
AlphaLurker
Postby notaturtle » Thu Sep 29, 2011 1:35 pm
I don't think anyone has even considered using tnt cannons against people but myself, and now you. It's good to set up defenses but I just don't see it happening. I talked to Scruffy and he told me he didn't plan on attacking you because he was too busy building, take that how you will.
War never changes
notaturtle
Postby Olothontor » Thu Sep 29, 2011 4:33 pm
notaturtle wrote:I don't think anyone has even considered using tnt cannons against people but myself, and now you. It's good to set up defenses but I just don't see it happening. I talked to Scruffy and he told me he didn't plan on attacking you because he was too busy building, take that how you will.
Both a relief and a bit of a diss... we're not worth his time, haha.
Postby notaturtle » Thu Sep 29, 2011 4:41 pm
Imperium was disbanded earlier... this may end up being more trouble than it looks like.
War never changes
notaturtle
Postby Ross_Varn » Thu Sep 29, 2011 5:13 pm
Hrm. Here's a bit of data for Lurker. And yes, I use the torch/gravel trick to great extent in mining- it destroys a stack in one go.
Enemies take 3 damage per block. This would be attacking from the rear- if this was in the courtyard, they'd still have to get past the gates.
Also, adding liquids on top the water would be an effective tactic as well-
-the lava particularly would be fun to watch. :D
Postby mgb519 » Thu Sep 29, 2011 5:19 pm
Have an outer wall, and put a minefield within that. Then we can retreat inside and BLOW THEIR SHIT UP.
Postby Ross_Varn » Thu Sep 29, 2011 6:01 pm
But then we won't be able to refill the wall while they attempt to break it underneath! I'm putting way too much thought into this.
Postby mgb519 » Thu Sep 29, 2011 8:37 pm
Why only have one line of defense?
Postby Ross_Varn » Thu Sep 29, 2011 9:25 pm
So your proposal is to do what they can't and blow it all up? We'll take that into consideration.
Postby 501stCadians » Thu Sep 29, 2011 9:36 pm
Put a dead man's switch. At the absolute center of the base, have a switch that will set off an immense chain reaction of TNT, leaving no trace of Bastion.
501stCadians
Return to blah blah minecraft
