Carnage(With Pictures!)
tahthing
Post by tahthing » Fri Jun 12, 2009 10:13 am
for building displays baseplates are a pain to use since: there expencive and the plate to cover them are explencive,you can't get fin lines,you can't do some of the stuff you can with SNOT.
How's that compression ratio?
RJ
Post by RJ » Fri Jun 12, 2009 10:19 am
agreed - and you can't put them on top of stuff - one of mine stapped the other day :(
Post by pesgores » Fri Jun 12, 2009 1:20 pm
RJ wrote:Thats it - according to a poll the forumer want to do a battle of the religions - I was going to give you a place as yourself(the triangluar pope in his pope outfit) now you just earned yourself the special ability to use baseplates
Awesome. If I get any temple or something, I want it BUILT ON BASEPLATE/S.
RJ
Post by RJ » Sat Jun 13, 2009 3:04 am
you start off in the triangluar realm - basically a load of black plates stuck together with an altar - i used a basplate to make the brikthulu temple but i can swap them round easily - i think the latter will look better with plates
tahthing
Post by tahthing » Thu Jun 18, 2009 4:49 pm
the triangle temple would be a triangle based piramide, that makes it hard to build.
RJ
Post by RJ » Fri Jun 19, 2009 10:16 am
well look at the triangluar temple made by pesgores himself in project pegosaur! ITS SQUARE!
Nitewatchman
Post by Nitewatchman » Sat Jun 20, 2009 1:22 pm
That was awesome.
I just wish I had taken some pictures of a battle I had thursday night...I built a two-story battleship with a launch catapult and fighters underneath, and a six-man command room on top. Every pilot can fire up to two guns simultaneously...
Nominees
-Nitewatchman
-Blitzen
-muffinman42
-Vami IV
WINNER: Nitewatchman
Post by pesgores » Sun Jun 21, 2009 5:44 am
RJ wrote:well look at the triangluar temple made by pesgores himself in project pegosaur! ITS SQUARE!
Well...that was a...rough draft of what I wanted it to be. The budget was low at the time (and still is).
RJ
Post by RJ » Sun Jun 21, 2009 6:02 am
i don't mind it not being triangular
the only way to do something triangluar with lego is to use connectors so i don't blame you
Post by Rayhawk » Tue Jun 23, 2009 1:39 am
Well that's not true, you can make a nice SNOT triangle by building the corner of a big box, and then lay it down with the corner pointing upwards. The proper use of slopes and angle plates where it touched the ground would make a very fine base for a triangular temple, no connectors needed.
RJ
Post by RJ » Tue Jun 23, 2009 9:43 am
i meant a triangluar pyrimid btw
Post by stubby » Tue Jun 23, 2009 11:14 am
tahthing
Post by tahthing » Tue Jun 23, 2009 3:04 pm
win!
Ranger S2H
Location: deep in dimmy territory, fighting the hordes from the inside.
Post by Ranger S2H » Tue Jun 23, 2009 4:23 pm
awesome battle, I like some of your word choices like: genocidified.
we need to make a brikwars dictionairy or just an ass of cool words to describe awesomeness.
on the off-topic: Im going to side with pesgores, baseplates rule!
Post by pesgores » Thu Jun 25, 2009 6:31 am
Ranger S2H wrote:awesome battle, I like some of your word choices like: genocidified.
My new apprentice!
