Krakow Union(Two Poland Threads!)
Not Lego but still Lego.
Moderator: The Shadowscythe
Re: Krakow Union(Two Poland Threads!)
Postby loafofcheese » Thu Jun 19, 2014 12:38 am
Anyone with a space polish vampire squid magic ship is worth a gold medal.
loafofcheese
Postby Silverdream » Thu Jun 19, 2014 9:07 pm
Finished it.
Adler Class Dreadnaught
The Adler was created in order to foster friendship between Bavaria and the Krakow Union. It was created to be cheap (for a dreadnaught), and easily reproducible by the Krakow Union without outsider resources. It's very heavily armed and armoured and it requires a very efficient power core. The core was designed by a team of Bavarian, Sicilian, TLA and Polish engineers and physicists, and it can create a lot of power (although the tradeoff is that it needs much more maintenance than other cores). While not powered magically, it does have a small temple for priests and mages to use for rituals.
The underbelly holds 24 Derangium torpedoes.
There's also a ton of parasitically docked fighters, using the classic Bavarian design.
Two derangium torpedo launchers are held in the front, and a vast amount of triguns adorn each side of the ship.
30 Fighters lay near the engines.
There are two massive radiant wave cannons on both sides. They require massive amounts of power, but they're highly effective.
The temple (pyramid).
Postby newcowboy » Sat Jun 21, 2014 3:49 pm
Brilliant! I love it. Can I haz LXFs? I need to to crush out enemies. Also, umm, in the Upcoming Bavarian War, do we have any other allies?
newcowboy
Postby Silverdream » Sat Jun 21, 2014 3:54 pm
Postby newcowboy » Sun Jun 22, 2014 9:21 pm
And I'm back!
WICHER-CLASS FAST ATTACK SHIP
Using the latest in Krakow and Bavarian Design, the Wicher Fast Attack Ship is designed with one thing in mind. Destroying as many ships as possible. to do this, they operate four massive Fusion Lances, ripping through armor and shields alike.
As well, they have four Forward Mounted Cannons, Capable of launching large Antimatter/Nuclear Munitions, designed to pierce and explode in a multitude of Hull-Ripping explosions and Radiation Bursts.
Using a new Engine Design powered by the massive Aetheroraad Reactor, it allows them to get into position as fast as possible. It also is more armored than the typical engine blocks of Krakow or Kiev designs.
It also parasitically carries 6 fighters, as a escort from missiles and other things.
____
So, that's my new Ship. Its designed to be a Defiant. Fire and kill everything in its path, and be fast enough to not die during these fights. Hopefully it will help in the upcoming Battle of Bavaria.
NOT DURING MAKING OF POST: I can't seem to get the pics to load, so for now, LINKS! If someone figures it out, spout a Post about how I'm a idiot.
newcowboy
Postby Silverdream » Sun Jun 22, 2014 10:12 pm
The problem appears to be that the images are over 1200 in size. 1200 is the size limit for width. If you have an imgur account, you can resize them.
Also, nice ship. It's sleek yet boxy and sort of utilitarian looking.
Postby newcowboy » Fri Jul 25, 2014 1:00 pm
I will not have the other great powers do better than me at my own original post schtick!
So, I have toiled and labored, and so, I present to you.....
THE VOID HUSSAR
Changing little from its original debut, the Void Hussar may see refit in the near future to upgrade it to match the recent influx of giant Mecha. However, two notable changes are in its weapons.
In Front of it are the two weapons systems of choice. It is a Large Four Barreled Minigun firing Plasma-Piercing Shells at over 5,000 RPM. This allows it to take care of fighters easily, or pierce through smaller starships, ravaging systems.
Then, there is the Trinium-OTC Lance. This is its main weapon, taking out everything in its path with style and grace, as it chops through turrets, missiles,and ships alike.
The only other change is the Miniaturization of the jetpack system. Now it is capable of easier movement in a much smaller package, thanks to Bavarian design.
NOTES: I have a design I like. I think the hussar wings stick out a bit, but I suppose we can chock that up to being able to rip through things easier, and having ECM or something, IDK. Mostly, I;m here to say I like the design, but I need moah Dakka. Any suggestions on how to apply said Dakka?
newcowboy
Postby Colette » Fri Jul 25, 2014 1:44 pm
Motion for a giant mecha fight over Bavaria. Scythian AT Fields vs. an OTC lance...
The hussar wings are awesome, by the way.
Postby newcowboy » Fri Jul 25, 2014 3:07 pm
Colette wrote:Motion for a giant mecha fight over Bavaria. Scythian AT Fields vs. an OTC lance...
Technological Arrogance versus Time Proven Power? I'm in.
I'll even get one of our greatest Lord Pilots in it.
newcowboy
Postby Duerer » Fri Jul 25, 2014 3:55 pm
That mech is pretty good, especially the wings, which look better than my walker's wings. I am still curious about Union ground forces, though.
Postby newcowboy » Fri Jul 25, 2014 4:35 pm
Duerer wrote:That mech is pretty good, especially the wings, which look better than my walker's wings. I am still curious about Union ground forces, though.
If I could actually make LDD Ground Forces, I would make them.
As for IRL, I have some soldiers and a tank, but no camera worth a cent.
newcowboy
Postby newcowboy » Fri Jul 25, 2014 5:12 pm
And Now, in a speedbuild to hopefully help with the battle at Bavaria, I have this.
WILK-CLASS BATTLECRUISER
A Battlecruiser designed to kill ships larger than it easily in a small package, then get awya as fast as possible, the Wilk Class is being pressed into production across the Union to support the upcoming Battle Of Bavaria.
To accomplish this goal, they have twin massive reactors, as well as the front Wave Cannon, designed to punch a massive hole in Battleships and smaller Dreadnoughts easily in a ferocious attack.
In a powerful broadside, they have Six Three-Barreled Turrets, as well as Sixteen Missile Pods.
Two Very Large Engines require almost half of the reactor's power to keep running at the speed they give the ship. This allows the ship to dance about the battlefield, avoiding too much damage.
20 Fighters are parasitically contained below, for fighter support to keep point defense up.
EDIT: And now both ships are up on the Wiki! If Dalinkski is still putting ships in, I;d love to see these in battle.
newcowboy
Postby Silverdream » Fri Jul 25, 2014 5:38 pm
Oh hell yeah, all of this new stuff is great.
Maybe I could host the Mecha-battle. The only problem is that I can't take great quality screenshots.
Postby newcowboy » Fri Jul 25, 2014 6:08 pm
Silverdream wrote:Oh hell yeah, all of this new stuff is great.
I'll be honest, the Wilk came from my sudden want to build a ship that was essentially two ships stuck onto a central superstructure.
Now, I might actually be wanting to make a army, since I;m on a bit of a roll. Any suggestions my loyal patron?
newcowboy
Postby BFenix » Tue Jul 29, 2014 1:29 am
The Void Hussars are plain awesome.
Return to LDD Forum
