Twin-linked weapons
Re: Twin-linked weapons
Postby Cytheran » Tue Sep 11, 2012 6:30 pm
IVhorseman wrote:But then either both guns hit, or neither do. I like the variability and excitement of not knowing if you'll get hit by the second one just because you dodged the first shot.
I see the logic and being BRIKWARS it makes sense. But why link them then? Its just shooting two guns at that point. Linking them actually would be worse in that case because you only get one target.
Cytheran
Postby aoffan23 » Tue Sep 11, 2012 6:39 pm
It all depends on how it's built, I guess. If you build a tank with two guns on one turret, then they'll be twin-linked. If they're on two separate turrets/sponsons, they'll fire individually.
not a country
not a country
Postby Colette » Tue Sep 11, 2012 6:47 pm
Without even reading this thread, which has become too long on such a "simple subject",
Rule of fudge.
I let my officers dual-wield pistols by rolling once for both of her pistol's skill and then once again for both of their damage rolls (i.e the damage roll is applied twice), with the cp cost of two pistols. Additionally both must be aimed at the same target. If I was statting larger twin-linked weapons it would work about the same way, but the only benefit I see from it is cutting down on the dice rolls. Otherwise, it's a rather useless addition, and one shouldn't go through the bother of declaring certain weapons to be twin-linked unless absolutely necessary.
:belushi:
Saved the USA
Saved the USA
Postby Cytheran » Tue Sep 11, 2012 7:40 pm
Colette wrote:Without even reading this thread, which has become too long on such a "simple subject", so I'LL make it less simple
Rule of fudge.
I let my officers dual-wield pistols by rolling once for both of her pistol's skill and then once again for both of their damage rolls (i.e the damage roll is applied twice to my dapperness) , with the cp cost of two pistols. Additionally both must be aimed at the same target. If I was statting larger twin-linked weapons it would work about the same way, bmiut the only benefit I see from it is cutting down on the dice rolls. Otherwise, it's a rather useless addition, and one shouldn't go through the bother of declaring certain weapons to be twin-linked unless absolutely necessary.
Cytheran
Postby aoffan23 » Wed Sep 12, 2012 5:41 pm
Rule of fudge.
Why would a pistol in each hand be twin-linked? Each hand aims and fires individually. That's like saying that your gunner can fire a machine gun and a cannon for one skill roll if they're pointing at the same target.
not a country
not a country
Postby IVhorseman » Wed Sep 12, 2012 7:05 pm
Yeah minifigs can't fire two ranged weapons under normal rules JUSSAIEN
