Simple Grappling hooks/jetpacks
Re: Simple Grappling hooks/jetpacks
Postby RunsWithLegos » Tue Feb 14, 2012 12:17 am
btw welcome back aoffan!
RunsWithLegos
Fox News watcher
Fox News watcher
Postby aoffan23 » Tue Feb 14, 2012 12:25 am
Well I've been back for a bit now, but thank you nonetheless!
not a country
not a country
Postby IVhorseman » Tue Feb 14, 2012 3:13 am
aoffan23 wrote:I guess we could give the minifig the action anyway; mainly for the greater potential awesomeness
Yeah, that's pretty much my entire argument right there.
Some grappling hooks are one-handed, others are two. Some are withdrawn by cabled winches, others by hand. In either case, a minifig would at least have the option to "sprint" up the rope/chain, no?
Postby stubby » Tue Feb 14, 2012 6:31 pm
I always just figured grappling hooks were one of the things you can load into a Launcher. Unfortunately this means that a regular minifig-carried launcher (max WS 1", so max PS" 0) wouldn't be strong enough to pull (reverse Launch) the minifig up by itself, so he'd mostly be climbing the rope under his own power. That's all fine, most grappling hooks work that way in real life in any case.
In order to do the Batman-style thing, that's where we need the custom rules, since the Launcher would have to be size 2" to be strong enough to pull the minifig up. I'd definitely force the grapple launch and the rope retraction to be on separate turns though, to give enemies the chance to mess with it.
forum janitor
Postby IVhorseman » Wed Feb 15, 2012 12:18 pm
Do you need spider gymnastix to climb rope at full speed?
Postby Gungnir » Fri Feb 17, 2012 1:00 am
What about swinging?
*raises shield*
Dice Sixes
Postby IVhorseman » Fri Feb 17, 2012 1:23 pm
Good question. I imagine that you can swing in a standard pendulum motion: if you are 4" away horizontally from the overhead beam you grappled to, then you may swing 4" past it. I'd also just fudge it and let you do a cool swing if you want to do a cool swing, though.
Postby IX_Legion » Fri Jun 01, 2012 7:40 pm
aoffan23 wrote:And if the tug-of-war lasts more than one turn, the hero will let go of the rope and shoot the people on the other side as they hilariously collapse and stagger into each other.
Fixd.
:sparta:
This should be in the Rulebook somewhere:
"Any problem on earth can be solved with the careful application of high explosives"
-Valkyrie (the movie)
IX_Legion
