Plastik Armory: Better Guns, Awesome Abilites
Thoughts?
All totally awesome, I'll be using these myself
44
56%
Pretty good ideas, some that I think could be better
26
33%
Hit and miss, lots of these don't make sense
4
5%
Mostly lame, some good ideas
1%
Horrendous, confusing and unfun
3
4%
Total votes: 78
Re: Plastik Armory: Better Guns, Awesome Abilites
Post by IVhorseman » Fri Dec 12, 2014 11:40 am
^^ Way to read the ability, shitlord ^^
IVhorseman wrote:Gun Kata: The minifig may treat ranged weapons as if they were melee weapons; they may use an angry inch, use two small arms against the same target simultaneously, and engage in all close combat with their guns. They still may not parry attacks, or use their guns as parts of charge attacks.
Frankly, I think it's a much much simpler solution than SN dice. My goal with most of these abilities is to let the SN dice take over for as much as possible, but for situations where I can think of an even simpler solution I want to share them with others.
Post by IVhorseman » Sat Dec 20, 2014 12:50 am
Apparently the rules have changed since I wrote these up, and loading is a move action, not a standard action. I'll still rule that Grenadiers always take an action to find a new explosive or upgrade an existing one.
Post by Gungnir » Mon Jan 12, 2015 1:53 am
Got another idea suddenly. Tell me what you guys think.
Stimulants
A needle full of powerful stimulants commonly found in a Medik's bag. Normally these are used to get a wounded minifig back on his feet, but when used on an uninjured soldier, they have some interesting effects.
+1 bonus to skill rolls: A minifig hopped up on Stimulants is better at everything. Nobody knows why.
+1" Movement: Stimulants give minifigs a boost of energy, allowing them to run faster.
+1 Effective Size: Minifigs can't feel pain when hopped up on drugs. This means they can take an extra point of size damage before dying.
At the end of the round, any effects granted by stimulants wear off. If the minifig has taken a point of damage, he succumbs to his wound and falls over on the spot, dead.
Post by stubby » Mon Jan 12, 2015 10:06 am
Nice, bet needs a better drawback. like
At the end of the round, any effects granted by stimulants wear off. Also the minifig dies immediately.
Post by Gungnir » Wed Jan 21, 2015 5:15 pm
That seems a bit extreme for a single-turn bonus.
Post by Gungnir » Wed Jan 21, 2015 10:04 pm
Or they crash when the high wears off and are unconscious for a turn.
devincp
Post by devincp » Wed Jan 21, 2015 10:14 pm
That is the best bad stuff for stimpacks I have heard yet. As long as they don't have any chance to try and get up.
Post by IVhorseman » Fri Jan 23, 2015 1:20 am
Honestly I just treat those little LEGO syringes as being able to grant an injectable supernatural d6 for one-time use. Works great every time!
Post by Silent-sigfig » Tue Jun 16, 2015 12:19 pm
CC WEAPONS MASTER +1
When using any Melee Weapon, the Unit's skill is increased by 1 die size. The unit gains an extra angry inch.
MARKSMAN +1
When using a Long-Ranged Weapon or Short-Ranged Weapon, the weapon's range is multiplied by 1.5 and damage die increase to 1d8.
SPIDER GYMNASTIKS+2
Units with Spider Gymnastiks may traverse along any surface, as long as they end their turn in a stable position. Units with Spider Gymnastiks always land on their feet, and are never disrupted.
BODYGUARD +1
As long as a bodyguard unit is alive, redshirt rolls are equal to skill.
MORTAR
Mortars always land 1 turn after they are fired, but land on top of their target. Any armor plating or shielding on the target is ignored.
Post by RedRover » Tue Jun 16, 2015 12:41 pm
Silent-sigfig wrote:CC WEAPONS MASTER +1
MORTAR
Is the landing site always marked or declared? So the opponent can attempt damage control
whiteeagle problems
whiteeagle problems
Post by Whiteagle » Mon Aug 03, 2015 10:49 pm
Voin wrote:
IVhorseman wrote:It already takes an action to load an explosive into a launcher
Does it?
I can't find anything about that in the rules. It seems more that it would be a Move Action, since loading a launcher should be routine for the crew operating it, while Standard Actions seem to be more appropriate for actions with a great degree of uncertainty in the outcome (accuracy of an attack, not falling off a rock ledge that you're climbing, cutting the right wire on a bomb you're disarming, etc.)
IVhorseman wrote:Apparently the rules have changed since I wrote these up, and loading is a move action, not a standard action. I'll still rule that Grenadiers always take an action to find a new explosive or upgrade an existing one.
Ah ok, I was wondering about this too, since I've come up with a different Grenadier Specialty that allows them to spend an action affixing a muzzle onto the Stud Shooters to turn them into Bastard Guns.
runnybabbit223
worth a try if your desprate
Post by runnybabbit223 » Thu Aug 20, 2015 7:37 am
IVhorseman wrote: To use a scope on a weapon IRL, it actually takes quite a bit of time, first person shootedrs are terrible at portaying this.
He's right you know.
3... 2... 1... DRAGONS!
whiteeagle problems
whiteeagle problems
Post by Whiteagle » Sun Sep 13, 2015 10:40 am
Whiteagle wrote:Ah ok, I was wondering about this too, since I've come up with a different Grenadier Specialty that allows them to spend an action affixing a muzzle onto the Stud Shooters to turn them into Bastard Guns.
Alright, I've decided to rename this ability to "Muzzle Attachment" in any case, and made it a free ability since the Stat-card Generator will still charge you the CP for listing both "Modes," which is also good because some Muzzles are also built to function as Melee Weapons.
Of course, when trying to Stat up my Tairin Electro-Marauders, I came across another issue...
Flying Units can only power their Length in Inches of Weapons instead of twice as many for regular Creations.
As the Electro-Marauder has a twin-linkable double two-inch Launcher/Gun for one arm, that's kind of an issue if each Launcher/Gun adds to the Power Limit.
Now I know it could normally be fired by using a Turn for Divert All Power, but I was thinking about the Heavy's Special Ability: Compensating.
Compensating lets a Heavy use weapons an inch longer than normally allowed as long as he isn't moving.
My idea for a Creation Ability, Really Compensating, allows a Creation to power an additional number of Inches of Weapons equal to it's Length AS LONG AS IT DOESN'T MOVE that turn.
Like Compensating, this Ability cost the same number of Construction Points as the original Length of the Creation, so it probably wouldn't be worth while for REALLY BIG Creations, but smaller things like Attack Helicopters and Flying Mecha would gain the ability to unload their entire arsenal just by sitting still that turn.
Post by Gungnir » Tue Oct 27, 2015 6:34 pm
Voin wrote:8. Can you fire both barrels of a Double-barreled Shotgun at the same target (as one can IRL)? What's the reload requirement (action or move inches?)
This is generally not a good idea, as it leaves the deer inedible. I've seen some shit.
StarshipH
Nice Dubs
Location: Death Star Exhaust Vent Maintenance Specialist Quarters
Post by StarshipH » Sun Jan 10, 2016 12:38 pm
Whiteagle wrote: Of course, when trying to Stat up my Tairin Electro-Marauders, I came across another issue...
Where is this (Flight = 1/2 weapons) in the rulebook?
I can't find it under Weaponry, Vehicles, or MOC Combat...
Just the friendly neighborhood Anorak, nothing to see here.
