Brikwars Chat - Enter the NerdZone
You know, whatever
Moderators: Blitzen, Almighty Benny, Silent-sigfig
Re: Brikwars Chat
Postby The Shadowscythe » Sat Dec 22, 2012 4:25 pm
WARNING - SCYTHE SHALT TALK SHIT ABOUT TONKS FOR A BIT
Colette wrote:Of course, this is just what I do. The best hovertanks just take the whole modern tank design and throw it out the window, examples including Scythe's Orpheus SHDT, blackdog's triangle-shaped SHDT, and my Space Näzi flying saucer M-B-T. Fredde's and the Luchardsko SHDTs combine the above two approaches- they look like a modern tank somewhat in shape but still experiment with some different methods.
For Kalvinators sake -
Basically, I fell for the pitfall of having a box with engines underneath and went through about 4 re-designs, both IRL and LDD before settling on this design which I am most happy with - incrementing the design with technic build techniques, a longer hull and more internal support while expanding on its in game roll - which is basically to be a high tech teir glass cannon.
It flies the fuck about as fast as most other armies flyers/fighters, it carries 20 troops to drop absolutely fucking anywhere and shit on anyones chips as needed, and its main weapons are designed to absolutely and utterly reaptrain the hell out of other STD's.
Yes it has shields in the fluff, but in the crunch, they wouldn't be anywhere near as tough as I sell them off to be in my army thread - as I said, it's a glass cannon split between the roles of -
- Fast as fuck speed
- Godkillingfirepower
- Troop capacity
Which means most of its time in game will be spent as a glorified sniper on rocket skates, blamming the hell out of the enemy and then running away before it then gets pinned and obliterated.
In terms of your own army however - I would recommend sitting down and having a good hard think about what it is you want your SHDT to do - are we talking about a slow moving brick of Armour and guns? B52 style? or a fast moving glass cannon with a possible secondary use? Or a floating troop carrier that only deals light damage but shrugs off most hits, and literally rolls into the enemy while vomiting troops left, right and center?
On top of this, does it fit your army style? And your play style to boot? You gotta consider this as well to make sure everything plays out your way.
Best of luck to yee dude, I look forward to seeing what you put out there. :D
The Brikwars Trickster God.
Re: Brikwars Chat
Postby Kalvinator » Sat Dec 22, 2012 11:04 pm
I don't want to dissapoint, but its not a SHDT, its just a regular tank that hovers instead of having treads. :oops:
This is a work in progress shot:
Yeah, the problem I'm having on it is that the bottom is just a flat plate, and I was wondering what do do to make it look better on the bottom.
If I ever do build something like that though, I'll keep that all in mind. Thanks for the long response, too.
Kalvinator
in need of one still
Re: Brikwars Chat
Postby Silverdream » Sat Dec 22, 2012 11:35 pm
A cheap way to make the bottom work would be to add triangular sloop pieces.
Maximus, I'm Dying
Re: Brikwars Chat
Postby Kalvinator » Sun Dec 23, 2012 1:24 am
I was thinking that, but I'm gonna have to check that I have enough pieces, which I"m pretty sure I don't.
Kalvinator
Re: Brikwars Chat
Postby Tzan » Sun Dec 23, 2012 12:51 pm
I like these:
LEGO White Plate Round 2x2 Rounded Bottom 4278271 (single,N)
3 or 4 of those look like repulsors and you can add a plate or whatever to make the tank hover a little higher.
Blockguy
Re: Brikwars Chat
Postby Kalvinator » Mon Dec 24, 2012 1:59 am
Yeah, I finished it tonight, but I'm gonna build one more thing, then do a NCR update thread. Thanks for all the advice.
Kalvinator
Re: Brikwars Chat
Postby Overwatch_Elite » Fri Dec 28, 2012 12:06 pm
Why is there an MJ12 bot?
"cut the man some slack when ur that dapper u never know when suprise dicks will show up gotta be ready 34/7" -Vami_IV
Overwatch_Elite
piss
piss
Re: Brikwars Chat
Postby Apollyon » Sat Dec 29, 2012 5:53 pm
Can i be an admin on the Facebook group? Reason: i want to kick out the Piltogg twat. My reasoning: he is not german and thus not good enough to wear swastikas. He will be pissed. Everyone wins.
Apollyon
constantly striving to using proper grammar
Re: Brikwars Chat
Postby Silverdream » Mon Dec 31, 2012 2:52 pm
Apollyon wrote:Can i be an admin on the Facebook group? Reason: i want to kick out the Piltogg twat. My reasoning: he is not german and thus not good enough to wear swastikas. He will be pissed. Everyone wins.
Fritz or Derek? Because one of them is a valued brikwarrior and old guard.
Edit: Now I know you're talking about Fritz.
Edit 2: What's even weirder for me is apparently Neo-nazis accept all whites (minus dapper gentlemen, half breeds and Jews).
Edit 3: He also seems to be a juggalo. I don't know what's worse at this point.
Maximus, I'm Dying
Re: Brikwars Chat
Postby Kalvinator » Tue Jan 08, 2013 9:44 pm
For Brikspace... Do you have to follow the rules of Max CP, cause for a Dreadnaught, 36 CP isn't nearly enough points to have all the dakka I have on it now.
Kalvinator
Re: Brikwars Chat
Postby Kalvinator » Tue Jan 08, 2013 10:07 pm
Also, do weapons need Cargo space too?
Also, is there a simpler version of microspace?
Kalvinator
Re: Brikwars Chat
Postby Colette » Tue Jan 15, 2013 9:38 pm
Epic chat:
<colette>: If the TA went to war with Brittannia, what would happen?
<theblackdog>: Your guess is probably as good as mine.
<colette>: It appears Klaus is in a position to assassinate Victoria.
<theblackdog>: I don't know whether she's a real queen or just a figurehead like in modern Britain though
<colette>: Gunpowder plot with SPACE GUY FAWKES.
<theblackdog>: DO IT.
Zahru's Waifu
Re: Brikwars Chat
Postby Whiteagle » Wed Jan 16, 2013 1:11 am
The next great Brikwars Hero... SPACE GUY FAWKES!
Absolute Twatpot
Re: Brikwars Chat
Postby stubby » Wed Jan 16, 2013 11:00 am
Whiteagle wrote:The next great Brikwars Hero... SPACE GUY FAWKES!
These guys are still waiting for a storyline: Inanimous
Natalya wrote:What's that? I can't hear you over the sound of how banned you are.
Psy.D Manchild Psychology, U. of Wikipedia
Re: Brikwars Chat
Postby Tzan » Wed Jan 16, 2013 11:44 am
All of my posts.
I do them for the Nunz.
Blockguy
Return to General Discussion
