Tooth
You know, whatever
Moderators: Blitzen, Almighty Benny, Silent-sigfig
Postby OneEye589 » Wed Jul 13, 2011 10:40 pm
The smell of teeth burning is horrible. Blecht.
Postby aoffan23 » Fri Jul 22, 2011 10:14 pm
OneEye589 wrote:The smell of teeth burning is horrible. Blecht.
Also, the taste of fillings is super nasty.
Postby morganm » Mon Aug 01, 2011 11:39 am
One tooth drilled?  Jeez... butch up sally...
Lost count of how many times the dentist has shoved needles in my gums and drilled teeth.
Two root canals.
Two crowns.
Last root canal was done by some quack who shoved the wrong size metal rods into my tooth so hard that the damn tooth cracked.  Holy shit was that painful!  Still haven't got that one fixed yet.... they are gonna have to pull it, do an implant into the jaw, and then put on a fake tooth....  :evil:
morganm
Postby Scottsman » Mon Aug 01, 2011 4:50 pm
I remember when I was getting braces I had a loose tooth they had to remove to avoid bad shit happening or something. Got the tooth pulled the next day and it hurt like hell, and looked like it had plenty of root still on it. So i'm sitting at home with some gauze in my mouth bleeding profusely when I feel something in my mouth wiggle. They had pulled the wrong tooth. It was at about that point I flew into a pissed off rage. Turns out they had accidently pulled out a perfectly fine, perfectly solid tooth with all its root still intact. It's amasing how loud you can yell with a mouth full of gauze.
Scottsman
Postby Silverdream » Wed Aug 03, 2011 5:51 pm
Do you guys really get your teeth pulled by dentists?
I've always been able to twist it off quickly.
Maximus, I'm Dying
Postby morganm » Wed Aug 03, 2011 5:59 pm
For my baby teeth?  No... I just pulled them.
Wisdom teeth I had extracted by an oral surgeon.
This cracked tooth will have to be extracted by a dentist or an oral surgeon.  I'm not sure if they will start the implant surgery right after it's pulled or if they do it later.
morganm
Postby Alex » Wed Aug 03, 2011 6:25 pm
When I was 16, I had to get all four of my wisdom teeth removed.
Alex
Return to General Discussion
