Consciousness
You know, whatever
Moderators: Blitzen, Almighty Benny, Silent-sigfig
Re: Consciousness
Postby muffinman42 » Wed Jun 20, 2012 4:25 pm
I remember only the vaguest details, mainly emotions. So my diary would be weird. I also get distracted by technical details so My dream diaries would be doodles of various things and notes about them.
Last night I honestly attempted to design a pump using materials that I knew I had and methods I could use, While avoiding pre-made parts.
Interestingly You can make a literal hand pump. Put your hands together so that your arms are at 90degrees (1/2pi radians) and clamp together firmly. Then keeping your fingers clamped move your palms away from each other and back again, you should hear a sucking sound and feel air coming out when you push together.
To make it a proper pump you need one-way valves.
The sticking point is the valves.
muffinman42
Re: Consciousness
Postby stubby » Wed Jun 20, 2012 5:25 pm
Natalya wrote:What's that? I can't hear you over the sound of how banned you are.
Psy.D Manchild Psychology, U. of Wikipedia
Re: Consciousness
Postby Ham701 » Wed Jun 20, 2012 5:31 pm
Is it bad that I immediately thought Gabe Newell when I saw the word valve?
Ham701
Re: Consciousness
Postby muffinman42 » Wed Jun 20, 2012 5:44 pm
Ball valves are easier to make than a screw pump.
take a length of pipe (I'll use 1cm diameter for the example), cut a piece about 3cm long from it.
Cut a 40mm circle in the middle of two 1cm square metal sheets, and in one cut several small holes around this but leaving the central ring formed from the first cut and enough support to make it strong.
Put a 50mm ball bearing inside the 3cm piece and then solder/weld the one with one hole to one end(call it A) and the one with many holes to the other end(call it B)
when the fluid goes from A to B the ball bearing will move and lodge in the central hole of B but the fluid will go though the other holes. When fluid goes from B to A the ball bearing will move and lodge in the hole of A and block all water going though it.
The sticking point is that I don't have any sheets of metal or any pipe lengths to fabricate it from, and that's the challenge. It's mcgyver style, not 'if i had...' style.
And Ham701, yes, yes it is.
muffinman42
Re: Consciousness
Postby Ross_Varn » Thu Jun 21, 2012 12:02 am
So you literally draft technical plans in your sleep.
That's... far more ridiculous than most of my dream-woven epics.
Blockguy
Re: Consciousness
Postby Tzan » Thu Jun 21, 2012 9:31 am
I make nuclear power plants in my sleep.
But instead of using radioactive uranium to make the water hot, I use radios.
Each radio is tuned to a disco station, which make the water molecules very angry and they start punching each other.
That makes the water boil.
Blockguy
Re: Consciousness
Postby muffinman42 » Thu Jun 21, 2012 9:44 am
Disco induction heating.
Power for the future.
muffinman42
Re: Consciousness
Postby Colette » Thu Jun 21, 2012 11:19 am
Re: Consciousness
Postby Ross_Varn » Thu Jun 21, 2012 11:57 am
-wait, did you do that intentionally, or is Stubby screwing with us again?
Blockguy
Re: Consciousness
Postby fredde » Thu Jun 21, 2012 12:35 pm
He did it the same way you can change the title on links but instead of writing "photo" "my video" or something like that. he wrote the link to a forum topic but the topic wasnt the "real" link but only the title of the link
Like so:
[ Derp url=http://trololololololololololo.com]http://www.brikwars.com/forums/viewtopic.php?f=7&t=8858[Derp /url
of course without the Derp
Natalya wrote:Fredde, you don't win the internet with this.
You ARE the Internet.
fredde
Re: Consciousness
Postby Ross_Varn » Thu Jun 21, 2012 3:57 pm
I've been around the forums several times, I know that much, but the link is to Shadowscythe's "crazy ass dreams" thread that actually is relevant. I just don't see why he would link the Trololololol vid to something that makes sense in the discussion.
Blockguy
Re: Consciousness
Postby muffinman42 » Thu Jun 21, 2012 4:01 pm
muffinman42
Re: Consciousness
Postby Colette » Thu Jun 21, 2012 4:08 pm
Ross_Varn wrote:... he would link the Trololololol vid to something that makes sense in the discussion.
It looks legit so people will actually click it. I've done this before too, I think the other time I was trying to troll silva or a new member, I can't remember.
Re: Consciousness
Postby Ross_Varn » Thu Jun 21, 2012 4:11 pm
Yes but it has nothing to do with oh fuck you nevermind
Cool video, MM
Blockguy
Re: Consciousness
Postby muffinman42 » Thu Jun 21, 2012 4:51 pm
All I can say is this thread is officially derailed.
Fun fact; The picture and video are linked! After the accident pictured, The entire K-class (from the picture) was rebuilt into the U-class (from the video!) because the accident was caused due to instabilities at high speed.
muffinman42
Return to General Discussion
