Lego doodles POST THEM
Re: Lego doodles POST THEM
Post by aoffan23 » Fri Mar 22, 2013 10:29 pm
I don't think it would matter if it was completely covered in armoor. If you do want to colour match, they both come in light grey and black, but the top one is expensive in black, and the bottom one is expensive in grey.
Post by Gungnir » Sat Mar 23, 2013 11:10 pm
Minecraft TNT blocks.
Or med kits. Whichever.
pkbrennan
Post by pkbrennan » Sun Mar 24, 2013 1:52 pm
You gonna count them as small explosives or size 1 explosives? Technically they are brick built ones so size 1, but could also pass for small.
Post by Silverdream » Sun Mar 24, 2013 2:05 pm
They should be size 3 explosives because it looks like they are made of three bricks.
pkbrennan
Post by pkbrennan » Sun Mar 24, 2013 2:31 pm
I thought plates didn't count unless they were enough to make up a whole brick?
Post by Silverdream » Sun Mar 24, 2013 2:39 pm
I thought that one had the potential to build a battlefield destroying bomb out of hundreds of studs. I guess it depends on fudge.
Post by Colette » Sun Mar 24, 2013 2:41 pm
Silverdream wrote:I thought that one had the potential to build a battlefield destroying bomb out of hundreds of studs. I guess it depends on fudge.
If half the studs are antimatter, then sure why not.
Post by Gungnir » Sun Mar 24, 2013 9:51 pm
I use inches for explosives. So size 1.
Apollyon
Post by Apollyon » Mon Mar 25, 2013 3:36 pm
Inspired both by Natalya's Space Canadian buggy as well as this little guy here.
Needs more work and some dakka most obviously. I grew somewhat bored with it however so it may take a while before i finish it.
Post by aoffan23 » Mon Mar 25, 2013 4:02 pm
That's pretty cool. I suggest that you lay off the dakka, and just slap a giant booster on the back of that thing instead. There's empty space, and it looks like the perfect vehicle to send flying off jumps and just causing ridiculous amounts of mayhem with.
Post by Silverdream » Mon Mar 25, 2013 5:31 pm
aoffan23 wrote:That's pretty cool. I suggest that you lay off the dakka, and just slap a giant booster on the back of that thing instead. There's empty space, and it looks like the perfect vehicle to send flying off jumps and just causing ridiculous amounts of mayhem with.
I'm in agreement. For Dakka, what about a giant fist attached to the underside of the vehicle for smashing everything it runs into.
samuelzz10
n00b
n00b
Post by samuelzz10 » Tue Mar 26, 2013 6:33 pm
rotating machine gun on the bottom and a cannon on the top will do the trick
my old sig
Post by Zahru II » Wed Mar 27, 2013 3:54 pm
I dig the 'suspension'
Post by Zupponn » Wed Mar 27, 2013 4:28 pm
You might be able to fit some sawblades on the front of that thing rather nicely.
Apollyon
Post by Apollyon » Wed Mar 27, 2013 5:02 pm
I like the idea of jumping on your opponets and instead of a fist i might install those two here:
Image + Image
