Modular terrain examples from Magnus
Postby Zahru II » Sun Mar 20, 2011 2:40 pm
Silent-sigfig is my new god now.
Postby piltogg » Sun Mar 20, 2011 2:59 pm
that looks mush more do-able
piltogg
Postby Pwnerade » Sun Mar 20, 2011 4:06 pm
Simple and elegant.
Pwnerade
Postby OneEye589 » Sun Mar 20, 2011 4:35 pm
That does look nice and easy. It really just depends on the resources of who's playing. I would like to try Magnus's system, too, for the trenches and things like that.
Postby Natalya » Sun Mar 20, 2011 4:58 pm
@Silent:
I like your ideas but covering a baseplate with a layer of bricks seems to be a rather redundant waste of parts.  The style in OP has the ground level as just a normal baseplate...  The idea was to come up with a standard height for baseplates with terrain to meet eachother at, which was 10 plates high.  I think it might be best if we conform to the  standards in OP because they won't use so many parts.
Postby Pwnerade » Sun Mar 20, 2011 5:25 pm
That is a lot of green bricks.
Pwnerade
Postby OneEye589 » Sun Mar 20, 2011 5:49 pm
With baseplates being the base level, people who DON'T have a lot of bricks and plates can build just basic level, too. People with a few can make a concave slope (baseplate level on two sides, slopes on the other two).
I know I've always wanted to play on those awesome battlefields from Lego conventions and this is an easier way.
Even just two people making two plates each, or four 32x32 plates and a 16x32 plate.
Also, this is just an idea for what some people could do. It would make for a beautiful battlefield to fight on.
Postby dilanski » Sun Mar 20, 2011 6:16 pm
Just to put it simply the scale of the armies people may be bringing to either battle would be huge. It would be lots of medium sized armies. if we get picky on terrain then we might have trouble fitting armies on a board. I think that building brick roads is a waste of time because you can buy ready ones cheap as chips. I'm not saying an ugly battlefield is fine, but being picky may limit us on battlefield set-up.
Postby OneEye589 » Sun Mar 20, 2011 6:33 pm
Again, this is for people who have the resources to do it. It's not going to be the Brikwars standard, but it would be fun to try once or twice.
If you want to have basic Lego road plates, that's fine. They fit exactly the same way as all the rest of them would in this system.
Postby Arkbrik » Mon Mar 21, 2011 12:27 pm
I made some trenches.
These are on 16x32 baseplates and leave the edge at the 4 studs in the middle.
Here they are as part of a bigger setup.
The problem with these is that either the whole field will have to be raised 3 bricks, or someone(s) will have to bring enough hill sections to get down from the higher level.
Postby Hoboman » Mon Mar 21, 2011 12:44 pm
Looks good, but I would have to get a lot more bricks to do anything of any real size using this system. But wonderful idea.
Hoboman
Postby OneEye589 » Mon Mar 21, 2011 5:26 pm
See? That's awesome.
Postby Natalya » Mon Mar 21, 2011 9:54 pm
Awesomeeeeeeeeee.  Yeah, all you need is some hill sections.
Postby Ross_Varn » Mon Mar 21, 2011 11:42 pm
Here's the gig. We each bring two or three specialized raised/lowered dirt/urban/whatever the hell you want baseplates [MOCplates], several flat and simple baseplates, and terrain that you can put down on the simple or MOCplates- forest/buildings/whatnot. Take masking tape and slap it on the bottom with your name, we can keep them seperate at the end of the day. This seems to be the best method of having a large brik-built battlefield. I'm working on location at the moment.
Postby enders_shadow » Tue Mar 22, 2011 3:35 pm
How about you can all bring enough baseplates to put your own armies on? because it doesn't make sense for Natalya to make two, then take up five. Also, I like Arkbriks better than Silent's, but his seems easier.
enders_shadow
