Star Wars Vehicle Creations
Re: Star Wars Vehicle Creations
Postby Whiteagle » Thu Apr 05, 2012 1:16 pm
So I've joined the Wiki, but everything on the test page is Microspace, so I don't know if uploading my tank is acceptable or not.
Anyway, after looking at the model I based it on, I realised that my Micro Droid Quadfighter's arms actually had one more joint then the full scale version.
I built a slightly more "accurate" version, but I'm not sure which I like more...
Also don't know if these fit in this thread or not, since they're Briktoid Automata ships instead of Star Wars Vehicles, but I don't like posting LDD things in my Armory thread so...
Here we have two examples of Briktoid Automata's "Transport, Utilitarian: Re-entry Drop-ship" or "TU:RDs".
They are little more then an armored cargo container with a thruster at one end.
Still, the comparatively slow, extremely poor maneuvering unarmed TU:RDs are excellent in their role of transporting resources from system to system as well as, more importantly, ferrying them between the orbit and surface of whatever mud-ball of a planet the Droids are willing to set foot on.
Ironically, the skinner one is probably my only recent LDD Creation that I could potentially build in Real Life, but I'd have to cannibalize two of my Droid Carriers and all of my STAPs for the parts.
whiteeagle problems
whiteeagle problems
Postby IVhorseman » Thu Apr 05, 2012 4:01 pm
I was gonna yell at you for turning a STAP into a larger, less mobile target with only marginally increased offensive power until I saw it detach as it's own scouting vehicle... nice work!
Postby Whiteagle » Thu Apr 05, 2012 7:12 pm
IVhorseman wrote:I was gonna yell at you for turning a STAP into a larger, less mobile target with only marginally increased offensive power until I saw it detach as it's own scouting vehicle... nice work!
Yeah, I figured if I was going to use a manned turret, then the droid on it would be pretty exposed.
So I like, "Well I'll make him a scout... and give him his own detachable STAP!"
Anyways, while I don't think it counts for this thread, I have been working on that "Conifer class" Briktoid Automata ship I've been talking about.
But I don't know...
...Do you think it could use more guns?
whiteeagle problems
whiteeagle problems
Postby Robot Monkey » Thu Apr 05, 2012 7:21 pm
Amazing name. Could a droid be packed inside? Then you could have a drop-pod assault.
EDIT: so you put Briktoid in the Third Alliance?
Robot Monkey
Postby Whiteagle » Thu Apr 05, 2012 7:28 pm
Robot Monkey wrote:Amazing name. Could a droid be packed inside? Then you could have a drop-pod assault.
Actually, the Conifer class is a Microspace Super Heavy Dreadnought...
Robot Monkey wrote:EDIT: so you put Briktoid in the Third Alliance?
Yeah, really they're only there as Mercenaries being paid in Vidagames and because my other two army concepts are on the other two sides of the Immortal War already.
whiteeagle problems
whiteeagle problems
Postby Robot Monkey » Thu Apr 05, 2012 7:30 pm
I was referring to the TURDs. Also, welcome to the TA.
Robot Monkey
Postby Whiteagle » Thu Apr 05, 2012 7:40 pm
Robot Monkey wrote:I was referring to the TURDs. Also, welcome to the TA.
Oh, yeah the TU:RDs are also Microspace Ships.
They exist because warships like the Conifer class are little more then weapons, armor, shielding, sensors, engines, and the computer brains that run them.
Briktoid Automata doesn't waste space with superfluous things like "Crew Quarters" or "Life Support" and they need something to move their ground troops from planet to planet with.
I could maybe build a Drop-pod using the same techniques, but for right now I just wanted a freighter.
whiteeagle problems
whiteeagle problems
Postby Ben-Jammin » Fri Apr 06, 2012 5:51 am
You can never have enough Dakka....
Ben-Jammin
Postby Ex_Bajir » Sat Apr 07, 2012 9:11 pm
But I don't know...
Needs more dakka!
Just kidding,there's no more room for any weaponry,at least that I can see.
Ex_Bajir
Postby heavyfishcannon » Sun Apr 08, 2012 7:16 pm
But I don't know...
Needs more dakka!
Need less ship! Moar Dakka!
"there are no bystanders in the battle for survival. anyone who will not fight by your side is an enemy you must crush"
heavyfishcannon
Postby Silverdream » Sun Apr 08, 2012 10:35 pm
Why not add binoculars and levers on the empty studs?
Postby Colette » Sun Apr 08, 2012 10:52 pm
Good point, all those large lasers will never do you any good if I can just deploy a dozen of my cruisers and swarm your expensive dreadnought to death with cheap, agile, fighters.
Postby Whiteagle » Sun Apr 08, 2012 11:00 pm
Silverdream wrote:Why not add binoculars and levers on the empty studs?
Admittedly, I left studs open in the event I ever actually built this thing and needed spots to attach stands.
Also, my new V-wing inspired me to built a similar starfighter:
Colette wrote:Good point, all those large lasers will never do you any good if I can just deploy a dozen of my cruisers and swarm your expensive dreadnought to death with cheap, agile, fighters.
...You clearly underestimate how Briktoid Automata operates...
whiteeagle problems
whiteeagle problems
Postby Colette » Sun Apr 08, 2012 11:04 pm
And how so???
Postby Whiteagle » Sun Apr 08, 2012 11:11 pm
Colette wrote:And how so???
Like you said, the Conifer class is a very expensive Dreadnought, an asset that should not be risked lightly.
Thus by the time one shows up, you've probably already been screwed over.
whiteeagle problems
whiteeagle problems
