A simple sketch
Moderators: Hoboman, Arkbrik
Postby kidko » Sun Jan 27, 2008 7:05 pm
Uh... more specific? But I'll describe my technique.
Just FYI, this is under GIMP.
First, I copied the sketch onto a new, second layer. Then, used the Color Selection tool to pick all of the white parts of the sketch and deleted them. I cleaned it up a bit, and what was left was a line drawing on an otherwise-transparent layer.
Next, a new layer under that. There I just colored it in, using the appropriate shading.
After that, I applied bloom (too lengthy a description, but I can explain it if you want me to) to both the figure and the white background.
And that's it.
Postby King of Brix » Mon Jan 28, 2008 3:53 pm
Gimp is awesome... Good technique Kidko... I would give a more metallic texture to the axes though... Probably using buttplugs > Emboss, then copying the layer and set to burn or something...
Red Clay Studios Click here, and read my latest battle report! More coming soon.
King of Brix
Postby Penguinlord » Mon Jan 28, 2008 8:40 pm
It says gimp works on mac if you set it for certin settings,
Return to Artwork
