Epic Fleet Engagement in the Caid Sector
Strana
Post by Strana » Sun Aug 30, 2009 11:58 pm
heres just a little snippet of the photos to come, the game took 8 hours and much destruction was had, later cp for the total battle will be calculated for major ships and shuttles, only, that wont include the men heroes or fighters.
bothe perspective fleets, before the start of battle
Roc's Fleet before start of battle
Strana's fleet before start of battle
Comparison of ship sizes
With a 2 liter soda bottle
there is obviously more to come but it will take me some time as im back in cloodge tomorrow youcan expacrt the first 3 turns up by tomorrow
DARN
Post by Warhead » Mon Aug 31, 2009 3:13 am
Looks amazing, good work guys.
lrdofbricks
Post by lrdofbricks » Mon Aug 31, 2009 5:17 am
this is pretty even, but i still think you need some work to match roc's ground forces. this looks to be a great battle though.
LEGION- fear it
the 100000 post- by me
Post by Arkbrik » Mon Aug 31, 2009 6:10 am
See, this is why we don't need microspace. Also, holy crap.
Post by Theblackdog » Mon Aug 31, 2009 6:33 am
Indeed. This is amazing. Also, ROC needs to post some of those new ships, I don't think I've seen them before.
Post by pesgores » Mon Aug 31, 2009 7:39 am
:shock:
THIS DOES NOT NEED BASEPLATES
501stCadians
Post by 501stCadians » Mon Aug 31, 2009 7:56 am
Crap. Pesgoures is back.
On the other hand,this is going to be the biggest and baddest battle yet. Sticky it!
Post by Magic Soap » Mon Aug 31, 2009 8:02 am
It obviously does not need baseplates, as combat is between, or in, ships.
Post by dilanski » Mon Aug 31, 2009 8:09 am
Question-what rules are you using, and does Roc have any surprises up his sleeve? as his fleet is tiny in comparison? Also is that a carrier i see?
Strana
Post by Strana » Mon Aug 31, 2009 10:32 am
Well we used mostly my rules for movement, 30" top speed, if not within 60" of an enemy shuttles, torpedoes, and fighters, could move double thier base movement. Modified HP system were for every 12" or fraction there of you get 5HP, (it still took 3+ turns to destroy some ships, smaller vessels HP was based on SL. (it still took 8 hours with the modified hp system, hence why we didnt, use standard brikwars HP. No warping, it actually wasnt needed, also to determine movement /LOS Ships, were likened unto ground vehicles, they can't go above or below eachother, and also this blocks shots, Shuttles and Fighters can however move past over onto larger vessels, and them selves.
DARN
RoC77
Post by RoC77 » Mon Aug 31, 2009 10:34 am
I'm not going to say too much about the battle yet(don't want to ruin it the ending), but the battle turned out into something like this....
The large ships arn't completed yet, so they won't be posted until then. (but there will be a good amount of pics of them in battle) The shuttle's I built on sat, so they'll be posted some time this week.
Btw... If you are thinking of doing a fleet battle, buy A LOT of dice!
Strana
Post by Strana » Mon Aug 31, 2009 10:42 am
First turn, there is an abandoned terrarium frigate in the middle of the field, Roc's tactics use this as a dividing line to hide his vessels, namely the fighters and D-pods
Fighters and D-Pods see deployment
Rocs, fleet at deployment
First movement
Stranas First turn, fighters torpedoes, and swarmer see deployment.
First movement
DARN
Strana
Post by Strana » Mon Aug 31, 2009 10:45 am
2nd Turn
One of Roc's shuttles decided to board the frigate, the boarder hears nothing but the scuttling of cockroahes, lets of a few point less blasts, to scare them away and moves to the command deck
*Chirp, Chirp, Chirp
Stranas Fleet Moves up the field fighters and shuttles punch it.
First engagements will happen next turn.
DARN
Post by Theblackdog » Mon Aug 31, 2009 10:47 am
Holy crap that's a lot of ships.
Also, I really hope that ROC's fleet tries to board Strana's big ship.
Strana
Post by Strana » Mon Aug 31, 2009 10:58 am
3rd Turn
Roc Moves his D-pods to ready to move out and shoot down the incoming torpedoes, The rest of fleet jockeys for firing patterns, The Destroyer, fires on the boarding pod. And the lone forward bomber gets fired upon.
Firing main CANNON
Fire almost all missiles
At the Bomber, also main cannon
There still comin
Stranas turn punch all fighters into engagement range, shuttles move to go after destroyer.
Beam cannon FIRE!!!!!
Roc's D-Pods react detroying one of the torpedoes
The fighters launch all they have the frigate, mexplosions ensue
Overwatch shot
DARN
